What microphone for audio reactive visuals?
xdjxklusivex
Re: What microphone for audio reactive visuals?
Post by xdjxklusivex »
So I tired audio input this past weekend using xlr to 1/8 out of our board. It was okay, some effects were cool others not so much.
Any effects that you know work really well with audio and suggest I try?
TBH, your input audio filter & FX envelope settings will be where the magic is at.
As for FX, I like displace, Exposure, Fish Eye, Distortion, and Shift RGB. I little can go a long way ;)
xdjxklusivex
Arvol wrote: Tue Sep 04, 2018 18:58 TBH, your input audio filter & FX envelope settings will be where the magic is at.
Ill have to play around with it some more this week. Reveal was pretty cool especially with tracks that had breaks.
cvanhoose
Post by cvanhoose »
Audio capture will have more control over a microphone feed, resulting better dynamics in the audio analysis.
Check out my free REACT set to get some ideas. There are a couple tutorials on the page to see it in action. The clips are purely generated with Resolume.
http://www.cvhvisuals.com/footageshop.html
xdjxklusivex
cvanhoose wrote: Wed Sep 05, 2018 03:21 Audio capture will have more control over a microphone feed, resulting better dynamics in the audio analysis.
Badass! Definitely going to check out the tutorials.
