Attached is my exported sys file for the BCF2000, use The editor application to import the sys file (or use cubase)
Editor can be downloaded here
B-Control Edit
In Resolume (2.3 version only!) goto preferences, then on the midi tab you will be able to load the resolume.xml file.
Link to resolume 2.3
Resolume 2.3 Download
I hope this help guys
ISIS
							BCF2000 configuration/help
				activstudios
BCF2000.sys & Resolume.xml
- Attachments
- ResolumeAndBCF2000.zip
 - (8.3 KiB) Downloaded 1320 times
				Anonymous
Hello,
I am also thinking about buying one of those. my question:
does the motor fader work great with resolume? (let's say it is at least possible to configure the thing somehow). i have heared the app must support midi-reset and midi-out to play with the motor faders.
the only reason for me tho choose this one is, that when i modify a parameter by mouse it is automatically changed on the controller as well (and vice versa).
help appreciated!
cheers
matthias
help appreciated!
cheers
matthias
				activstudios
BCF2000
Hi guys.
Resolume does not support MIDI out as Danger stated. But!..
I have set up mine as a solution to this!
I have preset1 as my main control for dex, main layer/s control etc. then I have preset2 for my EFX control.
What does this do? well, on preset1 say I had slider 1,2,3 at half way, and then I wanted to use the same sliders to control the effect parameters. I would change over to preset2, make the changes, then flick back to preset1 and my 1,2,3 faders would move back to where they where (motorised!)
Can you imagine if MIDI out was possible on resolume if RANDOM mode was applied!! I think the fader motors would soon see their day dont you?.
Does anyone still need help with the BCF2000?
[Edited on 13-10-2005 by activstudios]
and if you want control opacity and effects at the same time ?
in my setup i have
3 faders for layers opacity
3 faders for layers velocity
1 fader for scraths
1 knob for selected effect opacity
4 knobs for selected effect params
3 knobs buttons to active and inactive the 3 effects
3 buttons to select the active layer
3 buttons to select the active effect
14 buttons to call the effects that i use more offten
this is my configuration by now evey gig i had something
today i have posted my configuration files ... i'm not sure if this ones are my last configuration
http://www.resolume.com/forum/viewthread.php?tid=2020
						in my setup i have
1 fader for scraths
aarrggghhhhh
Am trying to config my new bcf2000
So far, all I can do is get:
knob 123 = velocity (twist)
fader 123 = opacity (slide up/down)
when I try to go further nothing happens
Ideally I'd like knob 123 to select each of the 3 layers also when pressed
or maybe the buttons under, but the buttons not being recognised either
and preset 2 for effects - well, the motorised faders work - made me jump when they moved, but also am having trouble assigning effects
If anyone has some time to help me get this sorted, I'd be everso happy
I dl the Behringer interface, and even that is being annoying, asking for above 1.04 after I dl 1.07 as it said and erm aarrgghhhhhhh
please help if you have the patience - I not have much hair left
Tish xxx
Tish xxx
can somebady help me ?
i have a post about the midi controler from EVOLUTION , the X-Session , and nobody answer me !
my bigest problem is that the buttons dosn t functions in resolume, i cant asign them, but in other programs they work perfectly (ex. TRAKTOR DJ STUDIO) , is there a way to make them work ? i realy need them !
10x
10x
				Anonymous
