Which bug?3polxin wrote: Wed Jul 10, 2019 03:36 Yes, thank you.... I hope this release can fix bug from the previous software
Resolume Avenue and Arena 7 Available Now!!!
OnlineZoltán
- Team Resolume
Re: Resolume Avenue and Arena 7 Available Now!!!
OnlineZoltán
- Team Resolume
Although sACN is on our radar, we don't have any plans for it yet.
I'm just happy my feature is finally here!!!!
https://resolume.com/forum/viewtopic.php?f=5&t=11434
whether at last it will be made CITP previews for lightings consoles ???
What I am taking from this pricing restructure is that now we're effectively paying for a "full release" amount of features in half the time between the releases of the previous versions which was already half the time of the previous versions etc etc. I'm just going to have to be honest in saying that this to me does seem a lot like a subscription lite model and it doesn't really sit well with me. The problem with this type of pricing is that too often we've seen companies cough*Autodesk*cough*Adobe*cough* start to phone it in and you find yourself paying more for less new features (or for no features) than in the past for major version releases.
What recourse will we have if a version is released a week before the licence expires and breaks a critical feature? My guess is buy another year of upgrade and hope for the best?
I hate to say it guys but I'm going to be rigorously assessing other options because VJing doesn't pay the bills too well and I need the most bang for my buck and I no longer feel that Arena is going to be delivering on that front.
OnlineZoltán
- Team Resolume
The big difference is that these companies don't let you use their product if you don't pay them regularly.StAngus wrote: Sat Jul 20, 2019 05:52 The problem with this type of pricing is that too often we've seen companies cough*Autodesk*cough*Adobe*cough* start to phone it in and you find yourself paying more for less new features (or for no features) than in the past for major version releases.
Your Resolume licenses, you keep for life.
In an unlikely event like this, you'll still be able to use the previous version where the critical feature works for you, as long as you want, without paying anything again.What recourse will we have if a version is released a week before the license expires and breaks a critical feature? My guess is buy another year of upgrade and hope for the best?
Then when it's fixed, and you decide you saw other new nice things you'd like, you can extend your license update period.
Have a look at this article on our support page: https://resolume.com/support/en/updates it should explain a lot in detail about how the new licensing system works.
Thank you for the reply Zoltan. Are you able to let us know what will happen in the scenario where one VJ is 'biding their time' and turns up to perform an event and is given a mapping file from another VJ who has the latest update? Will the mapping files be backwards compatible moving forward or will all VJs be required to be running the same version to load the mapping files? Cheers.
This is great news... just wondering (the notes seem to just cover the main new features) if there are any core improvements to performance or media handling?
We will always provide backward compatibility for files created with previous versions. If you save a file in version 7.0.1 you will still be able to open it in version 7.0.3, 7.1.0, 7.5.0, etc. If we're going to make changes to the file format that require a conversion, we will provide a conversion step similar to how v6 files can be converted into v7.StAngus wrote: Fri Jul 26, 2019 08:14 Will the mapping files be backwards compatible moving forward or will all VJs be required to be running the same version to load the mapping files?
What i think you're worried about though is forward compatibility, which is when v7.0.3 tries to load a v7.5.0 file. We cannot guarantee this to work. We aren't actively limiting loading of a 'file from the future'. What this means is that if the v7.5.0 file contains all the information v7.0.3 needs and it's in the correct location, it will be able to load it.
However, if that v7.5.0 file contains information on some imaginary feature, we wont be able to support that feature in v7.0.3.
yes!SiNiSon wrote: Sat Jul 27, 2019 19:38 just wondering if there are any core improvements to performance or media handling?
The notes mention OpenGL 4.1, we're using this for example to reduce trigger stutter. Some work has also been done on low performance when multiple outputs like capture cards , dmx lumiverses or virtual screens are used. You'll also notice major improvements to the recorder's performance. OpenGL 4.1 unlocks many new features for us which we'll be using to improve handling in the future as well. Maybe i'm working on using some of these as we speak
