4K output problem between Resolume 6 and Datapath FX4
Re: 4K output problem between Resolume 6 and Datapath FX4
Cosmowe wrote:I am interested in...why?
DisplayPort 1.2 supports both 4096x2160/60 3840x2160/60 whereas HDMI 1.4 only supports 4096x2160/24 and 3840x2160/30
...and I personally prefer the DisplayPort connector with the spring lock to the HDMI connector
kevin
Post by kevin »
cosmowe wrote: Tue Oct 15, 2019 23:07 Kevin,
Please send a picture if your bad image quality.
Best wishes
Cosmowe
Hi Cosmowe,
pls see the image in attached link: https://www.dropbox.com/s/1qfkcf257b11c ... x.jpg?dl=0
Many thanks,
kevin
Post by kevin »
Dear all,
I found and solved this problem, it come from Windows setting for scale text, it not use 100%, it recommend 300% for 4K so that why all image output from resolume scale and broken.
My mistake not double check it because before I only focus change resolution in Nvidia setting.
Thanks all for kindest support,
Perfekt.
