OSC trigger fault
Re: OSC trigger fault
Thanks,
I could recreate the clip disconnecting, with special timing, around the same than the clip's duration.
When I'm launching the column, just as the clip would eject, I sometimes can see the clip not playing any more.
We'll check what we can do, meanwhile I'd recommend just setting the clips to loop in Resolume directly, that way launching the columns again and again would not be necessary.
