Problem NDI output ...
AEK
Re: Problem NDI output ...
Post by AEK »
Thanks, Zoltán. Yes. We figured it out. Now the transparency mode works normally on the CLIP and LAYER tabs. On the COMPOSITION tab, it still does not work. But, as I understand it, this is due to the alpha channel that ARENA uses. In any case, with this situation you can already work. Ideally, of course, I wanted to use the transparency option, which is also managed on the COMPOSITION tab. Is it possible?
https://yadi.sk/i/Sh7rHXcdhF5Uiw
Best regards,
Andrey.
The Black BG refers to the slice itself, you can have multiple slices in a Screen in Resolume with specific RGB adjustment options and various overlaps, blends etc.
Fading the slices individually would change the looks, so what makes sense is to fade the output as a whole when using the Composition Master.
I hope this explains a bit why we're doing this.
What you could do to get your outputs to fade to black, would be using a separate layer on top of your content and playing a black solid color there. Then when you have the layer on Alpha blend mode, you could use the layer fader to fade in the black over the content.
AEK
Post by AEK »
Thanks, Zoltán.
You really helped us ... ...
Best regards,
Andrey.
You're welcome Andrey,
Let me know if there is anything else we can help you with!
