[IMPLEMENTED in 7.17] Set The Duration of a Recording Beforehand
DHoude
Re: Set The Duration of a Recording Beforehand
Post by DHoude »
Column render sounds like a great idea. When I was originally suggesting clip render, I too thought about the timings and things getting complicated. Which is why I asked for the simple clip render.
Maybe the only approach to times that don't loop evenly could be a time stretch. Meaning, change your playback time of the clip to an even multiplication or division of the longest clip. Then use a video router to capture all the layers below? Then Clip render on the Video Router? Looks like Clip Render is greyed out for that.
Online
Video routers and effect clips can't render offline, as they need an input texture. Clip renderer is also disabled for capture sources.
