Clip transform not working
Re: Clip transform not working
Arvol wrote: Sun Mar 27, 2022 20:17 Is this something in the XML that can be modified or does the the comp need to be rebuilt?
Let's check the composition and preset.
@Blatero If you have the option, make a backup of your Documents/Resolume Arena folder, and try to load the comp with the latest release.
Blatero
Post by Blatero »
Zoltán wrote: Sun Mar 27, 2022 20:25
Updating Resolume to 7.10 didn't make it; i installed windows 10 and tried that platform too, but still it isn't working fine, some of the clips keep being upscaled.
If it is about the texture size thing, have i to work on each clip to resize it?
Blatero wrote: Wed Mar 30, 2022 12:05 If it is about the texture size thing, have i to work on each clip to resize it?
Probably.
We can take a look at the original composition you have, maybe we can figure something easier out.
Blatero
Post by Blatero »
Hope I attached it right.
I'm still guessing why if i load the transform preset it behaves right, but reloading it keeps acting bad.
Where did you attach them?
