TouchOSC — Bypass Effect in Arena 7
T_G
Re: TouchOSC — Bypass Effect in Arena 7
Post by T_G »
Ok, all incoming messages do appear in the OSC inspector.
Strange is that bypass button should have “int” as value but it says “float”. Could that be the problem?
int would be best but buttons also work with floats. 0-50% will be off, above that it will be on.
Does the message address match to what you expect to receive?
T_G
Post by T_G »
Yes — it exactly shows what it is supposed to show …
Ok can you send a screenshot of that if it's still not working?
T_G
Post by T_G »
Hi Zoltán!
I have finally found the reason why it wasn’t working … There were blank spaces at the the lines which weren’t working. :roll:
Thanks so much for helping me!
Great to hear it works now! ;)
