NDI is only sending in 60p
Re: NDI is only sending in 60p
Hey again,
yes i am sure but double checking is always good.... and I did.. and wifi is still not active.
And even if wifi was involved here...that would be no explanation for butter smooth 60fps...and cookie crunchy 50fps ;)
what about the NDI tag fix ticket? Does the ticket still exists?
cosmowe wrote: Mon Jun 13, 2022 18:37 what about the NDI tag fix ticket? Does the ticket still exists?
probably, but if the monitor on your sender machine shows the signal nicely, the issue will be with networking somehow, and fixing the flag won't fix the issue you see.
Thanks Zoltán,
I will do some more testing on my side and update this post when I was able to hunt-down this issue.
Enjoy your day
