Fallo windows 11 ram
JhonyAlx
Re: Fallo windows 11 ram
Post by JhonyAlx »
Zoltán wrote: Wed Oct 12, 2022 10:43 So, what fixed it before?
Driver updates?
I changed the format of the videos with the alley
JhonyAlx
Post by JhonyAlx »
are you telling me that I should lower the frames per second of the capture device?
You also get a memory leak with vMix, when using these capture devices?
Well, if 25FPS mjpeg camera stream doesn't give you a memory leak, then yes change to 25 FPS ;)
We'll see if we can recreate this with the capture sources we have.
Can you send us one of the files which caused the memory increase?
elgarf
Post by elgarf »
JhonyAlx wrote: Wed Oct 12, 2022 13:40 are you telling me that I should lower the frames per second of the capture device?
You can try it.
