Intermittent tearing
brightpipe
Re: Intermittent tearing
Post by brightpipe »
vjkatza wrote: Thu Nov 10, 2022 08:38
brightpipe wrote: Wed Nov 09, 2022 17:39 I'm coming out of 2 DisplayPort outputs into 2 Inputs on a Novastar H5 Splicing LED processor. Each output is running at 4608 x 1728, it's the Left and Right half of the wall. The Composition is 9216x1728. The left half is DP 1, right half is DP2. Each side of the wall is also on it's own separate 20 output sending card. I did offset the seam where the 2 inputs come together from where the 2 outputs come together. The tearing remained on the seam between the 2 inputs, not the one for the 2 outputs.
After switching to the Quadro card I also tried to make a Mosaic Output which creates a single 9216x1728 monitor and assigning that as the output monitor in Resolume. But after doing that Resolume consistently crashes after running for about 10 minutes. After disabling Mosaic it's stopped crashing, but am getting tearing again.
One other thing I should note, I'm still on v7.3.2. Looking for a comprehensive changelog that lists all the updates/fixes to see if a newer version fixes the issue. I can try some newer versions to see if that fixes it. If the latest version will fix the issue I'll pay for the license renewal. But if they're just feature updates I probably don't need that.
Just install the trial of the latest 7.13.2 for testing.
I did that last night before I went home. I think it may have helped some. I've gone out to the warehouse and looked at it about 20 times so far today and only saw tearing once.
To try to figure out if its Resolume or something else in my setup, I opened a video in MPC-HC and set it to always on-top. Was going to try to drag that over the Resolume output to the seam between outputs to see if it they were both tearing or if it was just Resolume. By the time I got it dragged over and resized in right place the tearing had stopped again. Not sure if somehow doing that knocked it back into sync, or if it just got back in sync on its own. But it's been a few more hours and I haven't seen tearing again, so I'm not sure what is going on.
brightpipe wrote: Wed Nov 09, 2022 17:39 After switching to the Quadro card I also tried to make a Mosaic Output which creates a single 9216x1728 monitor and assigning that as the output monitor in Resolume. But after doing that Resolume consistently crashes after running for about 10 minutes. After disabling Mosaic it's stopped crashing, but am getting tearing again.
Were you able to send the crash report that pops up after the crash to submit a crash report?
Don't forget to fill out your email address, so we know it came from you ;)
