Auto BPM detection in Resolume 7
Rahul Gund
Re: Auto BPM detection in Resolume 7
Post by Rahul Gund »
Ya but it in Arena 5 it detects the BPM in Arena 7 it doesn't. This happens with all the music video in arena 7 it just shows 120BPM. Kindly fix this issue in next update. Thank you
Rahul Gund
With the new update, it didn't fix the issue. Kindly help m with the BPM problem it is not detecting the BPM of music videos that I put in Arena. Kindly Help.
Thank you
If there is no beat in the music, the BPM detection won't work.
Rahul Gund
But in Resolume Arena 5 it does work. All the music videos do get proper BPM detection in Resolume Arena 5 but in Resolume Arena 7 it does not work. If you can fix it that would be a big help for me because I want to upgrade to Apple M2. Resolume Arena 5 is 32-bit so it won't work there. Please try to fix this issue.
I am attaching the Images so you can see where the issue is and also I am marking it in RED. Please help
Thank you
This song is not 95 BPM, it's 64.
123 is about double, so I'd say that's more accurate, than 95.
I found the song in my library, and both v7 and v5 does 95 BPM for me.
That's not really correct, but also no wonder given the song style it is.
The BPM data for clips is stored C:\Users\[UserName]\AppData\Local\Resolume Arena/previews maybev7 read the tempo from cache?
How do your clips with proper beats calculate the tempo after cleaning the preview folder and restarting Resolume?
Rahul Gund
See I mostly play music videos with DJs so I need to match the BPM with them so the audio video plays in sync. In Arena 5 it catches the BPM but in Arena 7 it doesn't it always shows 120. I tried clearing the cache but it is still the same.
This is another one where there are only occasional beats in the song.
You can always set the tempo of the clip manually if the detection is not accurate.
Rahul Gund
okay thank you for the help
Rahul Gund
hello can you please tell me how to set the tempo of the clip manually so that it can sync
thank you
