Audio looses sync going into Final Cut OR Premiere.
Re: Audio looses sync going into Final Cut OR Premiere.
FractalMan wrote: Thu Mar 09, 2023 21:37 Ok, then if I'm recording 4k at 60fps is there a way to lock into that fps, or is it automatically variable? It dips to 59.75 in a few places, but mostly stays at 60fps.
If it's just 1 clip at that high of FPS and frame rate, is it better to Clip Render or Record?
The 60 FPS you can set in the composition settings is a maximum. If the machine can't keep up, it will fall below 60.
Clip renderer is offline, that won't drop frames.
If it also happens on a shorter recording, we'd love to check the recorded file out!
