Audio clicks when switching clips
jacoblamb
Re: Audio clicks when switching clips
Post by jacoblamb »
mikestjean wrote: Mon Apr 17, 2023 22:33
jacoblamb wrote: Mon Apr 17, 2023 21:55
Can you explain what you mean by 'clearing' clip A? Is clip B still playing? How do you 'clear' a clip / doesn't launching the next clip do this?
My apologies for not being more clear. All the clips in this example were on the same layer, so no two clips were playing at the same time for the sake of this test. When I say I’m “clearing” a clip, I’m referring to what you suggested - firing clip B which replaces A, but also clearing the layer via the big X on the track header produced the same issue.
Zoltán, the assets I was using were all DXV3.
Could you try a newer release after making a backup of your Documents/Resolume Arena folder?
Maybe this has already been fixed since 7.3.2?
mikestjean
Post by mikestjean »
Just bumping to see if anyone at Resolume has dug into this any further? Seems like I'm not the only one experiencing the issue...
Edit: oh there was a page 2, I didn't see... :shock:
...downloading the latest Ave. :oops:
Edit: ugh I hesitate to install OSX 10.15 right now... rather solve the issue with multiple audio tracks than update my OS and have nothing work :roll:
Will definitely report back when I get around to this. Thanks for all the advice!
7.12 release should not need Catalina yet ;)
mikestjean
I'll give 7.12 a try on my Macbook Pro shortly! Didn't realize you could update to non-current versions :)
I migrated the setup to a Razer Blade 15" Mid-2019 base model:
Intel i7, 2.6Ghz 6 core, Nvidia RTX2060, Windows 10
and using a Focusrite Scarlett Solo audio interface
running Resolume 7.15.0
I'm still getting the click sound (from Resolume) when triggering audio clips on the same layer, when another audio clip is already running on that layer, with a 2s transition :(
hmm, could you send over the audio files with your composition and a screenshot of the preferences audio tab to mail@resolume.com ?
