Memory leak on capture device
Re: Memory leak on capture device
Good to know :) Thanks bud
judicator
Post by judicator »
Hi! I just upgraded to the current version Resolume Arena 7.20.1 and the problem is still not solved.
judicator
Post by judicator »
Resolume Arena 7.21.2. Problem is still not solved.
judicator
Post by judicator »
Resolume Arena 7.21.3 problem persists
As stated in my previous replies, I'm NOT getting a memory leak on my system which is very similar to yours. (Win11, nVidia 40 series, intel cpu, etc.) It appears the problem is something isolated to your system and is not a global issue.
judicator
Post by judicator »
I checked this on 2 laptops and on both laptops i got this problem. So, it's not isolated problem. And similar not mean the same.
Christoph
Post by Christoph »
We're working on a fix for that memory leak!
Full Spectrum
Post by Full Spectrum »
Hi all,
Thank you for working on this! I can confirm this is occurring on our system as well. NDI HX input from two Panasonic PTZ cameras, as well as in and out from a Decklink SDI card. On our system, 128 GB, after about four hours of operation, regardless of user inputs or cues triggering, we've got about 30GB above expected, with a hung process that remains after Arena as closed.
And the FPS impact of this is a drop from ~90 FPS to ~40 FPS. Solved on program restart (and task manager process kill), but we obviously can't do this during show conditions. We open next week.
Thank you!! I really appreciate how responsive and diligent this team is.
Is your BMD output set to SMPTE color space?
Full Spectrum
I wasn't aware SMPTE (601?) was even an option for decklink cards. I have ours set to ITU-r BT.709. Full RGB. HD1080p59.94.
Would that make a difference with the memory leak? The show is open and running, so it's too late to make any changes, but I would certainly like to see a conclusion to this issue for next time.
