Post your 2.4 beta bugz here
lichterloh
Post by lichterloh »
tested it 7 hours yesterday. crashed once when dragging 20 jpegs 640x480 to a new deck. effect param1 in loop mode stopped playing twice. we can't change the number of bpm for the opacity slider.....didn't test vidnet yet- are the bpm sent as well over vidnet?
a great feature now would be in and out points for opacity slider......
the first time we started resolume and changed a clip to bpm play mode the tempo of the clip didn't change immediately as it was converted to bpm speed (for example 43 beats)- now every clip is changed to 4beats length- can i restore to this function or has it been a bug in the beginning? would be convenient anyway.......
we would really need the file name displayed pleeaaase.
really great improvements, we love it.
cat
Post by cat »
I had some issues with still images this weekend, tried jpg png and bmp, only the jpg loaded without error, bmp gave error message and didnt create a thumbnail (32bit) and the png gave an error, loaded without thumb but only showed the outline around the transparent bits.
illy
Post by illy »
it might not be a bug but:
i tried to set the "tap" button on my bcr2000 controler, and when i tap it, it gives me a value "500", even if i tap with 130bpm
i hope you understand me :)
LudikaStyle
Lower layer disappears
Post by LudikaStyle »
Spotted one bug:
I'm running two layers with .swf files, layer 2 is set to [At] @ 100%
sometimes the lower layer (i.e. layer 1) disappears and appears again only if I right click on the layer's clip container.
F
sj1972
bugs
Post by sj1972 »
Great work!
2 Bugs.
When I use the bpm feature on a clip that comes from a deck I made in ver. 2.3. It does not calculate the beat number - its always 4..
Sometimes the timing of the clip set with the bpm feature fails. It loops to the beginning of the clip and plays a little before the end of the beat.
Feature request...: midi control dial for bpm so you can adjust it manually and midi control for the number of beats on the layer and on the opacity slider.
Tnx for a great update.
Steen
syncopated.tv
illy
Post by illy »
Hey again
i remid me a bug that was also i 2.3 on saturday night i had it again. I use a lot of invert. And had something like this:
- i'm using a clip with invert,
- i take the next deck
- i delete the clip from the time line
- i play some piece of time with no fx, or any other than invert
- and suddenly i load a clip (non invert) and i have the ivert back
and everything without my permission, and i cant shut it off
rortes
Post by rortes »
just a small bug :)
mask of your logo resolume is up side down :P
http://img63.imageshack.us/my.php?image ... d01zk5.jpg
didnt use any mirrors or other filtres
checked the mask file and its okey...
ps. dont look at the clip becouse it happens on all of my clips... swf, avi etc
and yea i can confirm bug that sj1972 noticed : (please fix it fast! :))
"When I use the bpm feature on a clip that comes from a deck I made in ver. 2.3. It does not calculate the beat number - its always 4.."
[Edited on 26-7-2006 by rortes]
neok
bcr2000
Post by neok »
Maybe your tap button on bcr is not programmed right, try Toggle On or Toggle Off..
(I think your controller gives a signal when pressing the button and a signal when releasing)
hijack
Post by hijack »
Originally posted by gpvillamil
I had some strange behaviors with 2.4
I opened the filebrowser, dragged and dropped 20 videos onto the grid. The first 8 showed up almost instantly, and then things froze up. I pressed alt-Tab to switch context and bring up Task Manager, but then Resolume suddenly woke up again and loaded the rest of the videos.
Played around a bit, noticed some improvements in speed with 3x 640x480 MJPEG, but then Resolume crashed again when selecting clips from the grid.
It is possible that there is something in one of the clips that is causing the slowdown and the crash. However, all were encoded from same source using same settings.
Aside from that: the system for putting freeframe effects in categories according to folders is great! Makes performing with effects much easier. The BPM system is very handy.
I have not noticed a very dramatic speed increase when stacking up multiple layers.
[Edited on 23-7-2006 by gpvillamil]
i had the same thing
boo
Post by boo »
i've had it.
i have a hp pavilion zd800 with intel pentium 4 processor, 3.2 GHz, 1.0 GB RAM ,video card ATI Mobility Radeon X600, 256 MB, 400 MHz
WIndows XP 2002, codecs: ffdshow and DivDix Generation (Divx antifreeze, Divx G400)
last night i had an outside show which last for 1 hour and half and resolume 2.2 freezed for 5 times at least. it freezes since started to use resolume alomst 1 year and a half (2.0, 2.2, and now 2.4), but as often as yesterday, never.
the 2.4 just download it and didn't get to play anything couse it freezes when i just click a demo to play in a layer. i have no idea of improvements. in the past just crushes randomly..when i upload avi, mpeg, jpegs, doesn't matter what, looks like it is over loaded, but i worked with 3 avi's at one time, larger then a folder of jpegs. can;t figure out a clishee. and dispite the 1 GB RAM that i have, at a certain moment, resolume doesn't freeze but moves very very hard and i am forced to restart my laptop or at least restart resolume using ctrl+alt+del to exit. this is very frustrating.
plese let me know if there are better codecs that i can use or...anything that helps me at all.
vj b.
