Actual dream machine!! Unbelievable!
LXConcepts
Re: Actual dream machine!! Unbelievable!
Post by LXConcepts »
pfelberg wrote:This post is from 2006.
What is the current dream machine to run Arena?
I read about guys running this:
PC - 2.9GHz Xenon Quad Core processor, 12GB Ram, 2xNVS 420 Quadro
plus hard drives, SSD, etc...
And using 7 projectors.
What could beat this?
What´s the use of all that GPU power if Arena will still use just one? Will Arena handle all that outputs plus fx at 30fps? Is this a stupid question? ; )
that system does not have nearly enough ram...and those video cards are pretty lacking. Look at the GTX series- resolume works well with any cards built for multi screen gaming. You'll be able to drive 7 projectors, but I don't think you'll get much resolution out of them before your frame rate goes in the gutter.
my systems:
3930K, 32gb ram, gtx 780, 1 TB SSD, 1 TB HDD, BM HD/SDI Input card, Win 7
I can run a 16,000 x 16,000 comp at ~60fps and less than 50% processor load. Mind you, I'm only running 4 layers of video without effects.
Lighting and media server design
produktionshuset
Post by produktionshuset »
My current high end delivery and 3d rendering platform:
Intel i7 3770k, Asus maximus V, 4 Evga Titan cards, 32 gb of ram, and an array of 512 gb Samsung 840 series ssd disks.
BM intensity extreme (Thunderbolt), intous 5, Jazzmutant Lemur <- still love it after all theese years.
For smaller gigs or redundance i got a retrofitted MacPro 6core3,33ghz with 16 gb ram and 2*680 nvidia cards (extra powersupply/juicebox in the cd tray), intel 540 series SSD drives (i think thats their number) + Blackmagic intensity pro pci.
- for small venues - small events i use a MBP retina with matrox tripplehead, and the BM intensity extreme.
scottvjguy
Post by scottvjguy »
I am building a system right now for a permanent video mapping installation. Any advice would be appreciated.
The set up uses 10 projectors for a single 360 mapping composition and I would also like to be able to control the a 960 by 480 LED wall .
So I need 12 outputs including the GUI screen and would like to project at a composition size of 16,000 x 1200.
Can I do that with 3 GPU running 4 outputs each ?
Since I am only really going to take advantage of one GPU processor and resolume is a 32 bit program is it smart to use a system with less RAM and just one high end card while the other two gpu cards are cheaper models that still have four outputs ?
DayVeeJay
Post by DayVeeJay »
I think your computer is going to choke when you try to do anything with a pixel width of 16,000 pixels.
He2neg
Post by He2neg »
there was the idea somewere in this forum :
running multi gpu with multi resolume applications.
1 resolume per card...
but i dont think your 360° prjection will work then.
For this huge instlatiations you´ll need something more like a AV wings machine i guess
~Berlin~
drazkers
Post by drazkers »
scottvjguy wrote:I am building a system right now for a permanent video mapping installation. Any advice would be appreciated.
Get multiple servers synced by smpte.
