edited Wire patch now has all parameters set to their defaults
mowgli
Re: edited Wire patch now has all parameters set to their defaults
Post by mowgli »
I'm guessing that all this, is linked to this other problem, which I've posted here:
viewtopic.php?t=33185
In your video, the mode param changes.
Can you share the patch with the presets? You can send the patch folder zipped to mail@resolume.com
mowgli
Post by mowgli »
Have you seen the other post?
A similar and very strange thing is happening with the Text Animator preset Countdown from 10
Text animator is not Wire based, but it could be related.
mowgli
Post by mowgli »
This gets weirder and weirder.
If I drag the effect presets onto an empty clip, some of them display the characteristics of what happens after closing and reopening a composition, which does not reflect what the preset is meant to do.
Re-applying the exact same preset fixes the issue.
The more I look into this, the more confused I am. It's like there's a "ghost" preset in every preset.
Tried your patch (thanks)
I see the same in 7..23.2 release, pretty weird. Made a ticket for our devs.
Not yet, we're looking into it.
