Hmm, i know, that eee have single core =)). I just think, bcs Resolume works fine on my dual core AMD 3200, it's must work fine on eeePC tooVjSky wrote:First of all Resolume does not konow how to use multiple cpus unfortunatelyso dual core does not enhance resolume performance but it can be usefull if youre using capture cards and secondly the eeePC has a singlecore mobile pentium, it does not support the dulacore architecture.
As for plugins, I haven't tried them, but since it works fine at 630 mhz and 3 layers, i think it will work good with plugins @ 900
Will give it a spin and report back
btw, welcome to the forum
First Test: Asus eeePC 4G
Re: First Test: Asus eeePC 4G
I've, I have tested it with two outputs and it works fine, skips a little with 3 layers on chaos mode but its OK
Whats the process resolution you are using?
Ive tried 320x240 and vga, vga works but performance drops drasticaly when u add another clip, but for a lot of lo-fi gigs 320x240 is good enough, so it does the job...
What is the fastest CPU being advertised on the web today? What is frequency of the fastest CPU for a desktop computer being advertised on the web?
______________________
market samurai ~ marketsamurai ~ marketsamurai.com
oc'd Intel Core2 E8600 are saving the word records in SuperPi Benchmark, it's "only" dualcore... so for applications which use not more than 2 cores it should be the best solution!
