Resolume Avenue 3 is coming!
VJzoo
brilliant!! cant wait to get my hands on it. :mrgreen:
jim
Re: Resolume Avenue 3 is coming!
Post by jim »
FYI what Quartz Extreme graphics card means
http://forums.creativecow.net/thread/8/941306
dizzgo
Post by dizzgo »
Holy Cow!!
This is mighty!I'm looking forward to get the trial.
Great work and thanks a lot!!
VJ Brambi
Post by VJ Brambi »
Looking really nice! Cant' wait till the trial!
I hope my computer can handle it :/
mfo wrote:Wow, looks absolutely stunning! Very good combination of next-level ideas!
How freely can one control it by OSC (or MIDI) commands? For example can i use the Wiimote+GlovePie and move the layers around? Jump between the columns or snap to beats... ?
Glad you like it ;-)
You can control everything by midi or osc, so yes you can move the layers, trigger clips & columns quantized to the beat.
gpvillamil wrote:Any specs on what kind of resolutions and framerates are possible?
Difficult to say because it depends on the GPU on your videocard, the cpu and the hard-drives. All we can can say now is that Avenue runs fantastic on the MacBook Pro and that the days of 320x240 vj-ing are definitely over, it's 640x480, PAL and up from now on. More details coming soon.
Any way to script/automate?
Not within the app, but you can do this from any other midi sequencing software or hardware.
Best option if I already have Resolume 2 is the upgrade, at EUR 119, right?
Yes if you already own resolume 2 then the upgrade is 119 euro.
New users should buy before we release it in September because it's only 229 Euro now and you get a serial for Resolume 2 and 3. The serial for Resolume 3 works on both the mac and pc version.
slof
Post by slof »
Amazing guys! Just a quick question about Quartz Composer compatiblity. Can i play .qtz-files in Resolume 3 on a Mac and assign controllers just like in VDMX ?
jandybala wrote:Can you play the columns 1-9 as a pattern?
You can do this from any midi sequencer but not within Avenue.
incuf wrote:will there still be the number of beats assignment for clips?
Yes, synchronising video to the BPM clock works the same as in Resolume 2.
slof wrote:Amazing guys! Just a quick question about Quartz Composer compatibility. Can i play .qtz-files in Resolume 3 on a Mac and assign controllers just like in VDMX ?
In the first coming Avenue release you will be able to play Quartz compositions by exporting them as quicktime movies. We are very excited about generative content so we will add native support for .qtz-files and manipulating the exposed parameters in the (not so distant) future.
