Graphics Card
Re: Graphics Card
my problem was the omega drivers once I installed the Official Drivers it worked a treat
alexius420
Re: Graphics Card
any one know what the right driver would be for a nvidia nvs140?
Re: Graphics Card
i first heve the official and it was the same as with te omega driver so where is the problem
xp pro
intel pentium 4cpu 3ghz 2,00gb
nvidia geforce 6800gt
ps: some story as the one under!!!!
xp pro
Vj NoWig
The Visual Brothers,amsterdam
Re: Graphics Card
mmmm.. strange.. because before the omegadrivers i had the original driver.. same issue.VJzoo wrote:my problem was the omega drivers once I installed the Official Drivers it worked a treat
[edit] if i move the windowed output to the border of the 1st and 2nd screen, it runs as normal... (the window is just 1px on the 1st screen then)
[edit2] i registered resolume 3 with my serial, but it still sais Demo in the titlebar.. in the options menu it is fully registered..
alexius420
Re: Graphics Card
any idea what version of Omega drivers would work with my Nvidia nvs 140?
Re: Graphics Card
nowig wrote:more or less same issue...
Everything work fine on the first screen but when put on the second one this one freese.![]()
But when i put the windowed screen on the second screen and slide it to the first, i've got the image
does anyone know what the issue is ???
thanks
xp pro
nvidia geforce 6800gt with last omega 2.169.21 driver
to add to the strange part of this issue:
when i've resolume runing on the first screen with the windowed output on it too and that i move resolume (reduced) to the second screen than the output freese on the first one, and just work again when moved to the second!!!!???...
Vj NoWig
Re: Graphics Card
I have a Mobile Intel 965 Express Family Chipset
I went and installed the latest drivers and it says it supports open gl - but I get the error when I open resolume 3
its says my graphics card has insufficient specs.
Re: Graphics Card
I'm running a Geforce 8400M. WinXP, running nvidia drivers via laptopvideo2go.com
I'm getting the same issue as reported above, where the video output on DISPLAY2 shows as solid black. If I switch to a windowed output, the output works whilst it's on my laptop's display, but freezes when I move the window over to the secondary display.
craftycurate
Re: Graphics Card
"Demo" is the name of the default composition.GeeEs wrote:[edit2] i registered resolume 3 with my serial, but it still sais Demo in the titlebar.. in the options menu it is fully registered..VJzoo wrote:my problem was the omega drivers once I installed the Official Drivers it worked a treat
Re: Graphics Card
craftycurate wrote:"Demo" is the name of the default composition.GeeEs wrote:[edit2] i registered resolume 3 with my serial, but it still sais Demo in the titlebar.. in the options menu it is fully registered..VJzoo wrote:my problem was the omega drivers once I installed the Official Drivers it worked a treat
