so cinepak is faster and has lower image quality and indeo has superior image quality but takes up to 30% of your processor ...
so which one has the bigger file size / second or per minute?
and with wich type you have to code indeo (or cinepak) is it .mov or .avi? or else ... ?
the best quality video i've achieved - high praise for resolume
pxl addict_
indeed after testing ideo has much better colors than cinepak
so now, ideo for files where the color is important, and cinepak for others.
i think in vj-ing i'ts not bad when the quality is sometimes bad.
on my pc sometimes the quality is pretty bad, then i wonder how will the quality be on a big screen with projector... will it be even worse??? no!!!!
but the people are further away from the screen... so because of that, they might not see the bad quality. i don't know... never been on a gig... anyone else?
other question, whats faster, usb or firewire??? i've tried both, but i don't see a lot of difference....
(sorry for my imperfect english...)
greetz and goodnight
levon_
has anyone tried http://www.midivid.com/codec/download.html
its aparently the same decoding speed as indeo, but a bit faster at encoding. it would be interesting to see some comparisions to this codec.
pxl: usb 2 is faster then firewire, but firewire is faster then usb 1.
though firewire can be pluged between two computers and you have a network, which is faster then a cat5 network cable iirc.
digitalsnot_
vjBrye_
USB 2.0 vs. Firewire
USB 2.0 has a max data xfer rate of 480 megaBITS per sec while Firewire 1394a is rated at 400 megaBITS per second.
There is a new faster version of Firewire on the horizon. Firewire 1394b is rated at 800 megaBITS per sec. Microsoft is said to be releasing the first set of drivers to support this protocol this fall.
suggo_
but !!!! firewire guarantees you 400Mbits transferrate; usb2 not (depends on cpu and programms running and stuff);
anyone here accually uses dv-clips (720x576)
cause im just testing if i should go for quality in my next performances. as far as i tested its possible for me to work with to DV-PAL videos at 25 frames at 720x576.
Ruud_
Great!! I'm so far that I've got adobe premiere pro 1.5 and i'm coding my own footage now.
400x300
Indeo 5.10 codec
And I'm dubbing wheter to use 200Kilobyte/s or 800 Kilobyte/s like you (Edward).
Can you help me out, cause when I use 200kb/sec with 3 layers of video it slows down dramaticly in Resolume 2.0b.
Have a 1.6M Radeon 9200 64mb videocard with the omega drivers,
maybe it's more likely to use just 1 or 2 layers of video and third for flash?
Greetings, cheers Ruud HOLLAND
400x300
Indeo 5.10 codec
