3.1.3 BPM Sync Problems
rxfromparis
Re: 3.1.3 BPM Sync Problems
Post by rxfromparis »
any news??
14/02/10 : still no news?? is this just us??
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
Rene
Post by Rene »
I have exactly the same problem. Are there any news on this topic. A workaround? Anything else? - Please!
I want to trigger clips from Live, and without BPM Sync I can't do anything :(
rxfromparis
as you can see, there has been no real answer on this topic, and for a while now, so it would be nice if Bart let us know where they are on the subject???
We have made a few adjustments to the sync to make it a bit more robust, we'll release this in version 3.2 in mid April.
If you are still experiencing problems with that version then please contact us again, then it's most likely a bug that only happens with a certain combination of hardware.
Rene
Post by Rene »
Bart, thanks for the update on this topic. It's good to know that this will be fixed in the next release. :)
Looking forward to April!
rxfromparis
:D :D :D
VJ_IT
Post by VJ_IT »
Hi there, salut;)
Well first thanks to the developers and the community!
I just have something about that isue with broken BPM sync - it seems to be persistent and no solution was found so far..
Well It happened to me also (kind of digital disease perhaps?) so i thought it could be helpful to know some additional details about the circumstance under which it might happen - in my case it was like i just chanded my midi and also keyboard mapping settings completely - just switched from composition related mapping (i siply cleared that one) and mapped my interface for application mapping, hoping that it would be portable among sompositions then (which it was). But then this issue arised.
Thats it.
I am using Lenovo Thinkpad T420, i5 2520M 2.5 Ghz, nVidia NVS 4200M, but actually running resolume with integrated Intel GFX which seems to have better performace (wonder why btw:)
Hope it helps!
