Trigger Resolume Clips With Max for Live
Singing Pics
Re: Trigger Resolume Clips With Max for Live
Post by Singing Pics »
pantov wrote:you must have the osc plugin for max, or it wont work. :o
Yoohoo, thanks a lot!! I thought I'm too dumb to make it work. ;-)
Will try it a.s.a.p.!
Pandelis Diamantides
Post by Pandelis Diamantides »
Attached the [OpenSoundControl] Max external ("plug-in") for MAC and PC;
download & copy
--> (WIN)
\Program Files\Cycling '74\Max 5.0\Cycling '74\max-externals
--> (MAC)
\Applications\Max5\Cycling '74\m4l-externals
more in-depth info here: http://cnmat.berkeley.edu/downloads
OpenSoundControl_WIN.zip
OpenSoundControl - WIN
(23.32 KiB) Downloaded 1124 times
OpenSoundControl_MAC.zip
OpenSoundControl - MAC
(30.56 KiB) Downloaded 1171 times
