Quicktime DXV Codec and After Effects rendering crash...
Tschoepler
Re: Quicktime DXV Codec and After Effects rendering crash...
Post by Tschoepler »
Tschoepler wrote:Still the same error.
Updated QuickTime and DXV.?
:geek: I was hoping for it to fix the problem.
Any suggestions? What version of QuickTime are you using?
If you're still experiencing problems with DXV 2.2.1 then please email to support@resolume.com with an example AE project.
Cheers!
Tschoepler
whoops, I am sorry. Just found out that it has to do with some rights issue on one of my HDDs :oops: . Thanks for the reply. Everything's working fine now.
*edit* it wasn't rights but the naming. I had two HDDs with the same name (not drive letter). Seems as if QuickTime doesn't like that.
