Drop Shadow FFGL filter
damstraversaz
Re: Drop Shadow FFGL filter
Post by damstraversaz »
thanks a lot , that's really useful
Damien
digital arts:
http://www.damientraversaz.com/#!art-numerique/c1s43
music for dance, documentary and digital arts:
edwin
Post by edwin »
vjsmad
can't you use the Opacity of the effect parameter for Transparency?
Tecno`
Post by Tecno` »
That's great. I have been after an effect like this for ages!
If it had an option to adjust the softness (so it can have a hard edge) it would be perfect...
Thanks,
Tim
Tecno`
Post by Tecno` »
I tried this plugin on flash text files and it works great but when I use it on a video / jpeg with white words on black it does nothing. Is that because it requires the background to be alpha?
Thanks,
Tim
Yup. You can use it with video DXV+alpha encoded or PNGs with alpha though.
edwin
Post by edwin »
You can also use the Auto Mask plugin to create an alpha channel for you, it's not perfect but with the right footage it actually works quite well.
Tecno`
Post by Tecno` »
Automask works a treat! I hadn't noticed that plugin before...
Thanks guys.
Tim
I just wanted to make a feature request, but then I found this topic.
This plugin should find its way into the current installer. ;)
Screen Shot 2015-04-14 at 10.31.12.png (15.76 KiB) Viewed 28647 times
To everything, there is a season, and a time to every purpose.
sebabessone
Post by sebabessone »
Hi, is it possible to make the drop shadow effect reflected over the floor and not over the background? thanks
