Relocating clips
Re: Relocating clips
Can you send us your comp file and the complete path of the location of the clips?
asperi
Post by asperi »
please help
Summer13_720.avc
(1.9 MiB) Downloaded 461 times
What are the original file paths, and the new file paths?
asperi
Post by asperi »
Clips on external drives, comps either on those drives or in "my doc/res4" (pc). I went to another comp, resaved it, brought it back and it worked. But it has happened again trying to bring a comp to the pc I had resaved in, now that one cannot relocate load the locate clip dialog.. Is there a proper formula? I use the "relocate/ fix all" a ton.
I'm very sorry, but I'm assuming something must be going wrong with the exact naming of the paths. Perhaps there is a combination of variables that we haven't considered.
So I'm afraid 'on external drives' doesn't really help with trying to narrow this down.
Could you contact us directly?
