Chroma Key in Resolume 4
edwin
Re: Chroma Key in Resolume 4
Post by edwin »
The ChromaKey plugin that comes with version 4 can only be used in version 4 and up. So it won't load in version 3.
gpvillamil
Post by gpvillamil »
Actually, he's on to something. If you download the .bundle file from Assembla.com, what is downloaded seems to be an empty folder and takes up about 14k. If you dig down into the Content folder and then to binary, you have what appears to be a 78k file. So something is missing.
The Windows .dlls work fine as is.
There must be a secret to downloading the OS X .bundle file as a .bundle. If someone knows it, please share...
zejuju wrote:
Rene wrote:Hello zejuju,
You could just copy the .bundle to the Resolume vfx foler: /Applications/Resolume Avenue 3.3.3/plugins
After restart you should see the plugin in the Effects Tab. If not, check the Resolume log file.
thanks Rene for your help. But this crasy :) I never see it appear, I tried several times as you said, even redownload the plugin thinking it could be corrupted, but no... And the log files says :
load plugin: /Applications/Resolume Avenue 3.3.3/plugins/vfx/FFGLLumaKeyInverse.bundle/Contents/MacOS/FFGLLumaKeyInverse
load succeeded
Life is crasy ;)
Thanks anyway.
zejuju
Post by zejuju »
Hi gpvillamil,
yes that can be it, because i still don't see it appear, the FFGLChromaKey.bundle is not loaded.
gpvillamil wrote:Actually, he's on to something. If you download the .bundle file from Assembla.com, what is downloaded seems to be an empty folder and takes up about 14k. If you dig down into the Content folder and then to binary, you have what appears to be a 78k file. So something is missing.
When i had this conversation with Rene last time about the plugin loaded :
Rene wrote:
zejuju wrote: load plugin: /Applications/Resolume Avenue 3.3.3/plugins/vfx/FFGLLumaKeyInverse.bundle/Contents/MacOS/FFGLLumaKeyInverse
load succeeded
I doubt that this is the plugin you've downloaded. Search for the filename of the bundle.
Yes that was a mistake but since then I tried the FFGLChromaKey.bundle's os plugin and it never loaded.
So yeah if someone has the secret, please share ;)
vj granda
Post by vj granda »
zejuju wrote:Hi gpvillamil,
load succeeded
Here you have the answer, 2 posts before:
edwin wrote:The ChromaKey plugin that comes with version 4 can only be used in version 4 and up. So it won't load in version 3.
zejuju
Post by zejuju »
Ah ok vj granda...
I thought this plugin ChromaKey by Matias Wilkman on assembla.com was made for Resolume 3.3
and I thought too thet the answer by edwin was an answer to my first question about adding this chromakey plugin to R.3.3 later on.
vj granda
Post by vj granda »
I agree, I think that Mattias' one is made for R3, too.
Rene
Post by Rene »
Well, seems to be a lot of confusion here.. :D
The thread title says "Chroma Key in Resolume 4" - so yes there is a native FX and it works fine.
regarding Resolume 3 and the FX from Matias: You can download it from the assembla repo. However their HTML browser plugin does not recognize .bundles, and I guess that's the problem here. If you use a SVN client, your get the proper bundle file. Otherwise the bundle is interpreted as folder. For that reason, I just attach a zipped version of the ChromaKey FX developed by Matias Wilkman (http://matiaswilkman.blogspot.com/).
FFGLChromaKey.bundle.zip
(52.78 KiB) Downloaded 1109 times
zejuju
Post by zejuju »
Rene wrote:Well, seems to be a lot of confusion here.. :D
:D yeah !! Thanks a lot Rene, all is great now, no more confusion, love when the clarity comes back. ;)
This one works now, Resolume 3.3 load it. Thanks again, you have solved a major problem i had for my set.
Yeah downloading it directly wasn't working well, now it's cool....
zejuju
Post by zejuju »
and thanks to Matias Wilkman ! :)
vjsmad
Post by vjsmad »
hi everyone
i worked on the chromakey developpment and made many test during months i can tell that quality is amazing and can be compare to real time hardware as Ultimatte chromakeyer so if you need chromakey buy version 4 !!
