File formats ??
stevespaw
Re: File formats ??
Post by stevespaw »
Thanks for the reply Joris,
I understand you have priorities and a market that you need to support.
I apprieciate the Information and perspective and will continue to follow the progress.
There is a market where people are using lesser products like playback pro, when you have such potential.
BTW, we are looking for Windows solutions.
Thanks again,
Steve
videohead
Re: File formats ??
Post by videohead »
My immediate goal is to determine which containers and codecs Resolume will support for general purpose playback, and not get into a "DXV is good/bad" discussion. There are some specific reasons why DXV will not work for my specific uses (no batch transcoding support, not supported in current transcode operations, I am playing back media from many professional and non-pro producers who have not heard of it or cannot change their workflows), so I need to move forward and make decisions about what IS supported if I am going to use Resolume.
The following were tested on a Windows 10 Computer running Avenue 4.5.2, exported from Premiere. I avoided all standard definition settings.
Yes, in MOV container:
QuickTime ProRes LT and 422
MP4
MJPEG
H.264
(You have to append .mov to the file extension to get these to work universally)
Yes, in AVI container:
MJPEG
Container not supported:
MXF - it does not matter what codec - Joris has confirmed that this will not ever be supported in email to me.
.MP* container - no variants of MPEG seem to be supported
WMV
M4V
M2T
MTS
Codecs Not Supported:
DNxHD
MPEG
DVCPro
OP1a
GoPro/Cineform
BlackMagic 8 or 10 bit
Windows Media
Also apparently not supported:
Network drives
In my opinion, a pretty restrictive list with no support from major professional media applications, which puts into strong question whether Resolume should be considered a professional application.
Please let me know if you have others to add to this list.
Re: File formats ??
videohead wrote:no batch transcoding support, not supported in current transcode operations.
Adobe media encoder has a nice feature called watch folder, where you can drop your files and the converter queues the files with the specified transcoding settings and starts automatically.
I have a preset with fps, resolution set to match source, video encoding set to dxv, audio set to 48k wav.
This works even for jpg and png.
It would be worth trying.
