the reason wht it goes frontward and backward is because uppon following the music I have my midi controler to control the strengh of wich it listen from -1 to 1
FFT Timeline !
Re: FFT Timeline !
here a little example of what you get when playing in resolume with the patch
Re: FFT Timeline !
i miss the vizualiser.pd in the new file and don't have the old one which is offline now
besides that the ir-osc plugins work fine, this patch(es) may have more possibilities
Re: FFT Timeline !
yes it does, I use it to control many actions,
one single fader can control as much parameters and effect with different values and FFT and BPM sync, just a bit of logic,
for ex the RGB delay has this fantom from last time you disabled it imae everytime you enable it, so I have this sligh delay directly on puredata osc part for opacity and its now perfect in resolume
if ppl are still intrested in this or need help or file, my mail : censored
