"Next Column" trigger/button in Arena
SystemD
Re: "Next Column" trigger/button in Arena
Post by SystemD »
Update to V3 : control multiple computers over lan.
http://divisionpixel.com/download/next- ... esolume-v3
For testing, thanks for your feedback :)
tobyspark
Post by tobyspark »
+1 for this feature. Was quite surprised it wasn't there. Edit: Waa!? It is there for MIDI map, but not OSC or Keyboard. Am I missing something?
Also, set BPM from a column trigger, as per Ableton.
tobyspark wrote:Waa!? It is there for MIDI map, but not OSC or Keyboard. Am I missing something?
Yes, you are missing something. I assume you are referring to the mappable > icon that appears in Midi and DMX mapping modes. That's not a Next button. What it is, is explained here: viewtopic.php?f=12&t=12326
tobyspark
Post by tobyspark »
Thanks.
Rossnz
Post by Rossnz »
BBBBUUUMMMPPP!!!
Please say this feature is coming in 5.1.
This would make our lives so much better.
While the above are cool, we run Win not OSX and dont really want to run Java on our servers
oleutne
Post by oleutne »
SystemD wrote:Your can try this app i made a few month ago with Max 6: "Next Track Resolume"
My application is here : http://divisionpixel.com/download/next-track-resolume
(Only for Mac OS for the moment, sorry)
Installation:
- Connect a MIDI device - USB
- Start Resolume
- In the preferences of Resolume, click the "OSC " tab. Set the input port (OSC in) on 7100 .
- Start "Next Track resolume"
- Choose the MIDI device in the drop down tab
- On the device , choose two keys that will be used to navigate through the columns.
- Indicate the number selected notes in the boxes "Next" and "Previous"
I've the Max file, so, if someone want to do a windows version, send me a MP ;)
When I try to download your application, I just get to a page saying "Sorry, no posts were found". Did you take down the file?
SystemD
Post by SystemD »
The location has changed on my website : http://divisionpixel.com/applications/n ... -resolume/
You have to subscribe to download and you have access to a forum now to write some comment about this app ;)
SHAGALOV
Post by SHAGALOV »
Hello everyone!
here is little App for Mac users:
COLUMN GO (written in Processing)
https://yadi.sk/d/F_cHM1ta3HGMij
very simple for install:
- Copy "ColumnGo" to Application folder
- Start Resolume
- In the preferences of Resolume, click the "OSC " tab. Set the input port (OSC in) on 7000 . Set OSC Output to 7001 and switch off Bundles
- Start "ColumnGo" and Enjoy
it's work with mouse click or Spacebar
ajamusic
Post by ajamusic »
SHAGALOV wrote: Mon Apr 24, 2017 09:56 Hello everyone!
- Start Resolume
When I try to start the app my mac says the app is damaged and to trash it! Have you got another download link to an undamaged version?
I'm very much hoping to be able to use my space bar to trigger the next column on Arena 4
SeanBannister
Post by SeanBannister »
For anyone finding this from Google, I presumed this didn't exist after reading the forums but I believe its since been added, I found this accidentally:
First enable layer transition controls....
Then to change columns use the buttons circled in red:
These buttons can be mapped.
