Windows 8 Support
- rawdesigns
Re: Windows 8 Support
yeah my windows 8 can load SOME flash files but nothing in the clip section works it just blank and Resolume doesn't crash.
Same here. Recently upgraded to Windows 8 and using Resolume 3.3.2, the software crashes when loading a flash file.
I installed the newest demo edition of Resolume 4 to see if that one does work, but same problem there.
Kinda problematic when I use an editable text-box in flash a lot during my VJing, to interact with the audience.
Hope this gets solved soon!
David
David
Flash support will be fixed on the next update.
It's taken a bit longer because we decided to re-write a lot of it. We kind of got tired of Adobe breaking it with every update.
seems it's fixed with 4.1.4 ! thanks!
