And again I want to say that I already find Resolume very cool and the only thibng I'm trying to do is to help improve it, not criticize it for fun.
I also understand how difficult it could be to manage memory.
But I don't totally agree with you when you say "if you have a decent HD it,s not a big problem."
I think I have a decent HD (Maxtor 7200 rpm 8Mo cache) and I also think it's a big problem, for the perfs when playing 2 or 3 channels at the same time and also for the health of the disk...
I don't know but it makes so much noise when you're playing 2 or 3 channels at the same time... I imagine that in a wet and hot party environnment (+ the music vibrations) and I wonder how many times my HDD will support 2, 4 or 6 CONTINUOUS hours of that treatment...
Of course if you have 3 * 500Mo clips you cannot put them in your total 512 RAM But isn't there a way to use a "put that in RAM" command and if the RAM is already full then it goes to the pagefile or something ?
Isn't Windows already using RAM like this ? in an automatic way ?
at least for the active clips... please... I promise I'll be kind...
You say :
"This is because is it quite hard to find a good mix of reading from the hd and ram loading. "
I understand this as (tell me if I'm wrong) : We know how to put clips in RAM but we don't knw/don't want to spend too much time on Managing free RAM vs Clips size to avoid mem problems
Am I right ?
If so Can't you include this as an option ? event experimental one with warnings.
Like an "Load active clips in RAM" options
And it would be the user responsability to use it or not regarding the RAM he has and the Clips size he plays ?
I know I'm very demanding but as I said before that's juste because I fond Resolume to be the best VJ app (IMO) when it was in version 1.5 (and I tried A LOT of others like Arkaos, VJam and so on...) and when version beta 2 came out it has all the ergonomic issues I had with v 1.5 fixed or improved (multiple decks, swap channels, msg for already used shortcuts, better multi display support)
[Edited on 4-11-2004 by Rincevent]
