2 Resolume Arena OSC Problem
fatih
Re: 2 Resolume Arena OSC Problem
Post by fatih »
Could you tell me how to use this files? "oscfilterforwarder"
May be add to system folder or Resolume folder etc.
Or working with 3rd party app...
Fatih
nicholas
Post by nicholas »
I just tried with resolume 5.0
it seems there are still some issues,
the clip played on the slaev is not fitting the composition, unitil you press the scale to composiiton button.
and when you play another clip, it makes the same problem when you come back to the first one.
but when triggered directly from the slave, it fit.
strange ....
would be so great to have resolume working good with slavec and master computers.
would make no limit in the number of projectors.
nicholas wrote:I just tried with resolume 5.0
strange ....
I saw this issue with a different video card on the other machine with a different maximum texture size, thus the same float value describes different parameters values for the clip sizex and y.
