Eye of the Storm.
Loving the stingy sphere. Haven't ever used it live, but now might start.
Create Visuals with Resolume and Win an Arena License!
- Vjcheshire
Re: Create Visuals with Resolume and Win an Arena License!
- Attachments
Eye of the Storm.avc- (141.18 KiB) Downloaded 1437 times
My experiments in Resolume. In 1920x1080 looks good i think
- Attachments
resolume effect [1833].avc- (121.07 KiB) Downloaded 1250 times
- Attachments
EF1.avc- composition
- (67.94 KiB) Downloaded 1259 times
- freakiebeat
These two clips are called Bug Hunt because of the bug I found in Resolume while creating it/them. Bug Hunt #1 is the clip specified by BugHunt.avc when loaded into Resolume without modification. Bug Hunt #2 is the same clip after the project screen resolution was switched from 640x480 to 800x600. Saving the project at the new resolution and reloading produces Bug Hunt #1, so the only way to get the Bug HUnt #2 effect is to load the project with a 640x480 resolution, then upping the resolution to any other setting and NOT saving the project.
The Resolume folks should have fun finding & fixing the problem.
Bug Hunt #1
Bug Hunt #2
Bug Hunt #1
Bug Hunt #2
- Attachments
- BugHunt.avc.zip
- (3.69 KiB) Downloaded 1427 times
- saxelectro
Real time processing by the sound of Drum to the Video FX (mapping) and Audio FX.
The location of that video capture was at Athens Municipal Symphonic Orchestra rehearsal hall, and the drum belongs to the same orchestra. Many thanks for the support.
Created and performed by Andreas Mourtzoukos (saxelectro)
For more informatiom please visit: http://saxelectro.com
All Rights Reserved
Andreas Mourtzoukos
Saxophonist / Composer / Cross-Media artist / Digital Scenographer / Webcaster
www.saxelectro.com
www.saxelectro.com
@Freakie Beat. It's not a bug. When you add a Solid Color, it's created at the composition size (640x480). When you then change the composition size, the Solid Color stays at 640x480. Just match its render width and height to have the same output at a different resolution.
Oh, and
Oh, and
Code: Select all
[youtube]video url goes here[/youtube]- freakiebeat
@ goto10 - I would consider it a bug because - If I'm getting output for a particular .avc file and I hit the save project button, then reload the save project back in, I would expect the very same output that I was getting when I hit the save project button... anything else but the the output I was getting previously means that the at the time working parameters were not actually saved as they were being rendered.
If you really want to start this discussion, please open a separate topic.
- digital:snot
very fun contest ... great way to nudge us out of our creative shell...
really must be viewed in 720p though...320 is nasty
it really pops when you animate some of the line parameters (width rotation position and fuzz) and wave parameters to an external audio beat like a bass drum..
- Attachments
- COSMIC INTERFERENCE.zip
- (4.54 KiB) Downloaded 1766 times
here is mine
thats mine, im using trial version
- Attachments
Resolumecontest.avc- (75.65 KiB) Downloaded 1339 times
