different videos to different projectors
Re: different videos to different projectors
turiel wrote:.. I guess you'd need set the positional values on each video file you load individually, and you'd still be using two layers so might not be the best way.
you only have to set the position once per layer as shown in the video, not for each video.
if you need a clip on the other side just copy it to the other pos. layer.
you could add a crop effect to cut away video that would leak to the other side on layer level.
repeat for as many layers as you need.
turiel
Post by turiel »
oops, sorry. didnt notice how he clicked and moved from the Clip tab to the Layer tab. They are kind of similar so didnt catch my eye.
