4 Screen duplication plugin please test
hive8
Re: 4 Screen duplication plugin please test
Post by hive8 »
He2neg wrote:Working as should, everything fine.
But to be honest i cant think of a situation to use it.
Mapping is done via slices / output
Mirror Quad & Videowall is usefull for the rest i need. But maybe if someone show how he/ she use the plugin i will find something as well.
The good thing about plugin is that if you dont need it dont use them :). Other people have situation where they would love to have it, its up to the user what he wants to use or not. I my instance I love to have it. Not forcing anyone to do something they dont want to do.
Das ist alles was ich sagen wollte. es ist gut was zu haben wenn Du es brauchst ;)
Programfeed
Post by Programfeed »
A couple requests now that I've used this in a few shows:
-- Four sided cropping options per-screen
-- "Black BG" toggle to add solid background behind all screens (would save me a couple layers and routes!)
hive8
Post by hive8 »
Absolutely.
The first idea I am working on already.
Second i didnt think about but makes sense.
May I ask on what shows you used it.
Programfeed
hive8 wrote:Absolutely.
Most recently at the Ultra Miami Worldwide stage. I planned to use it for more but the lack of those couple things I mentioned has been limiting for my workflow. Will gladly pay up for the pro version!
Yuckfou157
Post by Yuckfou157 »
Thank you very much for this, I should have seen this sooner, just 2 days ago I was struggling to duplicate my DJ cam unto different slices, doubling and mirroring, but this will do the job perfectly, so again, thank you very much! :)
hive8
Post by hive8 »
Your welcome, I updated the version for the windows version, it includes now a overall black BG. Also compiled VS2013 so no need to install the windows redistro 2015.
H8_FFGL4ScreenV1.001.zip
Version 1.001 with black BG and 2013 compiler
(7.6 KiB) Downloaded 939 times
pkpictures
Post by pkpictures »
anyway you can unlock the 1080 cap, so we can test on larger comps?
hive8
Post by hive8 »
Absolutly I will take that out in the next version... Please give me this week.
hive8
Post by hive8 »
pkpictures wrote:anyway you can unlock the 1080 cap, so we can test on larger comps?
Btw from the plugin itself i dont think there should be a cap on the resolution, but if there is I will take it out.
The only time i use hard coded values was where i calculate the slider values on which are the light gray colors on the right of the slider. Let me know if I am wrong with this.
Digitrevx
Post by Digitrevx »
Hey Hive8 is there a version that works with R6?
