Datapath Fx4
jaydeeshow
Re: Datapath Fx4
Post by jaydeeshow »
Nothing still, 1920x1080
Re: Datapath Fx4
custom resolution in windows
I'm attaching a zipped folder with the program for your fX4 and the ASS file for Arena 5.
Jaydeeshow Rescue.zip
(2.81 KiB) Downloaded 563 times
Re: Datapath Fx4
...and I forgot to mention that next time you're in the San Francisco Bay Area you owe me a drink ;)
jaydeeshow
Re: Datapath Fx4
No drink, dinner and red wine. I'll be home in 1 hour. What I have to do with ass? My aunt lives in San Francisco
Re: Datapath Fx4
ASS is the jovial acronym for Advanced Screen Setup in Resolume ;)
Just unzip the folder I sent you, and drop the .xml file in the Resolume Arena 5>presets>screensetup folder then restart Arena 5 and the preset will be available in the ASS. Then open the .wdl file with Wall Designer and associate your fX4 by right clicking on the device in the device tab.
jaydeeshow
Re: Datapath Fx4
Oaktown, I've followed your suggestion but still was not working. I've decided to upgrade the flash and now 2 projectors are not seen in the input..?!?!?!?!
Re: Datapath Fx4
What kind of projectors are you using?
jaydeeshow
Re: Datapath Fx4
Hitachi cp WU 5500
jaydeeshow
Re: Datapath Fx4
Now they all work and are 1920x1200 60 hz but resolume it's the same only 1920x1080
jaydeeshow
Re: Datapath Fx4
Resolume it doesn't see it. For now I've unplugged and testing the 3 projectors directly on the gtx and my friend Vj it's saying to install another gtx so I have 5 output. Can this be a solution?
