Anyone who's affected by this please send us the file that's created on your desktop when you run with this command in a Terminal window.
sudo ps -A >> ~/Desktop/processlist.txt
Thank you!
Can't open my recent purchase of Resolume Arena 6
Re: Can't open my recent purchase of Resolume Arena 6
Today just bought a new version
i can't open my recent purchase of Resolume Arena 6
Please help identify the cause and solution
- Attachments
- Arena_2017-11-24-233426_kim-MacBook-Pro.crash.zip
- (20.77 KiB) Downloaded 426 times
We are still working on this issue.kim199077 wrote:Today just bought a new version
Please help identify the cause and solution![]()
Try logging in with another user, to see if you can start Resolume.
Zoltán wrote:We are still working on this issue.kim199077 wrote:Today just bought a new version
Login another user can be opened, but replaced by the main users, there will be an error
Ok, until we can get this sorted out, please use a different user for running Resolume.kim199077 wrote:Login another user can be opened, but replaced by the main users, there will be an errorZoltán wrote:We are still working on this issue.kim199077 wrote:Today just bought a new version
Thank you!.
KelSweeney
I'm having the same problem with Resolume 6
It was running fine in demo mode then once I entered the registration licence it constantly crashes on launch.
I've attached a crash log and the terminal file log. Hope that helps.
- Attachments
- Crash logs.zip
- (25.15 KiB) Downloaded 531 times
- Igor_Cardoso
Irmãos estou com o mesmo problema, não consigo abrir o Resolume 6 por nada!!!
Brothers, I have the same problem, I can not open Resolume 6 for nothing !!!
- Attachments
- problema Resolume.zip
- (21.22 KiB) Downloaded 551 times
Your issue appears in 6.0.1, you should be able to use 6.0.0. fine.KelSweeney wrote:Hi,
Hi! I'm having the same problem. When downgrading to 6.0.0 the problem persists. This seems weird, because before upgrading to 6.0.1, that install worked fine...
My last version of Arena 5 still works.
Thomas Goddyn
http://www.tBEDRIJF.be
KelSweeney
Thanks, yep, that seems to be working now.Zoltán wrote:Your issue appears in 6.0.1, you should be able to use 6.0.0. fine.KelSweeney wrote:Hi,
