Slice Transform
- rawdesigns
Re: Slice Transform
how do you use slice transform to toggle on and off different slices? like if i had a logo to go across every panel and i wanted different options it would be easiest to toggle off different panels and have logo only on dj booth for example
						- rawdesigns
Re: Slice Transform
rawdesigns wrote:how do you use slice transform to toggle on and off different slices? like if i had a logo to go across every panel and i wanted different options it would be easiest to toggle off different panels and have logo only on dj booth for example
Re: Slice Transform
Take a look at this video that explains how to map your logo in various locations using the new slice transform feature. As a note, I didn't go into mapping shortcuts as I'm sure you're familiar with that.
						- rawdesigns
Re: Slice Transform
Oaktown wrote:Take a look at this video that explains how to map your logo in various locations using the new slice transform feature. As a note, I didn't go into mapping shortcuts as I'm sure you're familiar with that.
Thank you! Very helpful!
