Slice Question
pfelberg
Re: Slice Question
Post by pfelberg »
Zoltán wrote: Wed Feb 02, 2022 17:11 And now it's 30FPS with the same TV?
Was it running without the AC adapter before at 60?
Seems like you're not doing the comparison with the same parameters.
Nope. At the site it was running at 60fps with the AC Adapter On.
At home, I obviously tested with the AC Adapter on. It was smooth and also running at 60fps.
What I meant was that even without the AC adapter on, Arena was running at 30 FPS and play was still smooth.
So, why wouldn´t it also play smoothly after connecting to a projector?
thanks
Paulo
Re: Slice Question
Hard to guess.
Did you see the stutters on the output only or also in the Resolume monitors?
pfelberg
Re: Slice Question
Post by pfelberg »
Zoltán wrote: Tue Feb 08, 2022 13:45 Hard to guess.
Mostly on the output. I didn´t set an output monitor other than the output itself. It would be a nice test to do.
Paulo
Re: Slice Question
If the UI monitors don't stutter, I'd say things go wrong after the image leaves Resolume.
