Congrats....can you get a bit more into detail?
Best wishes
Cosmowe
Flashing Scanlines - SOLVED!
Re: Flashing Scanlines - SOLVED!
Do you like outlines? Easy Outliner on Juicebar Re: Flashing Scanlines - SOLVED!
The nvidia panel presents two tabs on 3d configuration. The first one is for global configuration. The second, to specific software as Arena, for instance.cosmowe wrote: Sun Jul 14, 2019 10:54 Congrats....can you get a bit more into detail?
Best wishes
Cosmowe
So, in Global Configuration, V Sync is set to "use 3d software configuration" (may vary translation). While in Software Configuration V Sync is also set to "use 3d software configuration".
Haha dont ask me what is the current 3d software configuration.
