Autopilot with BPM Sync can't keep up (7.2.1)
cdelguercio
Re: Autopilot with BPM Sync can't keep up (7.2.1)
Post by cdelguercio »
Thank you so much for sticking with me through all of this :D
Some day I'll have to visit Hungary and buy you a drink!
No problem;)
What I found is when I set the composition frame rate to something really low like 5, the auto pilot actions pretty much break.
Do you have the composition set to 30FPS, or is one of your output displays 30Hz?
Can you try setting the composition frame rate to Auto, and check if this gets you higher frame rates, and if that helps with the looping?
cdelguercio
The composition is set to Auto in the test that I emailed you guys.
For my original large composition it was set to 30. I'll change it to Auto and then stream with it tonight and see if it changes things.
cdelguercio
I did a set with it the frame rate at Auto and it seemed to work over the ~1 hour session. It was outputting at 60fps. I still wish it would work at 30fps since that's what I stream at and I don't want to stress out my cpu/gpu more than necessary.
Great to hear it worked on auto!
At least there is a workaround until we can figure out a proper fix.
theLABVisuals
Post by theLABVisuals »
I think i had the similar autopilot issue earlier ..
viewtopic.php?f=12&t=20023
Good to see more uses experiencing issues :)
tomasraimondo
Post by tomasraimondo »
Hello, were you able to find the solution to the problem?
Exactly the same thing happens to me, I have 6 layers that have to be advanced with autopilot, some videos have sound and others do not.
The autopilot works when it wants to, sometimes it stops for no reason and hangs on a clip when it should move on with the rest...
Has anyone found a solution?
Thanks a lot,
i use win 10. resolume 7.2.1
please help me.
thank you
Set the clips to Timeline ;)
