Multichannel Audio Output planned?
marachas
Re: ¿Ha planeado la salida de audio multicanal?
Post by marachas »
resolume arena, for many years it has been my favorite software and main work tool, many of the advances it has had have fascinated me but just as resolume has evolved, my knowledge and the demands of the shows have also evolved.
and now I feel that resolume has been left behind and that it is advancing very slowly compared to the demands of today's shows.
work with compositions larger than 12k px
optimization of computer resources
hardware solutions for advanced capture and compression
(I have had a lot of excessive delay when inserting several transform slices into a Blackmagic SDI source)
smidt@smidtaudio.de
Re: Multichannel Audio Output planned?
Post by smidt@smidtaudio.de »
+1
Please, please, please don't ignore the users. This ist requested since years and is needed so badly...
smidt@smidtaudio.de
four additional months are over an we didn't heared anything of mulitchanel audio output. Please, please, please, we need this feature badly :-(
So they need to hurry up or what? :P :D
Always a good idea if you need something to be solid and reliable.
It will come one day.... till then you can try the timecode trigger, for example Ableton workaround if you need something now.
Best wishes
JohnnyMauser
Post by JohnnyMauser »
+10
Not being multichannel ready was allmost a showstopper for me!
Luxcollective
Post by Luxcollective »
+100 (a boy can dream) Have a show in early December that needs 3 to 5 channel audio playback. Doesn't even need 5.1 decoding, I will have the 5 separate audio files (Just needs to be able to play and route the multiple audio files to a multichannel sound card just like we can play and route multiple video files to multichannel video cards :-)
Ugh, the extra failure points of Qlab+timecoding across main Resolume rig and backup.
ToCenTek
Post by ToCenTek »
+1
Multi-channel support is so useful!
pahaahv
Post by pahaahv »
This question just popped up in a meeting at my workplace. What are the alternatives? What workarounds could one use?
I need to play a video (commercials) to my sound guy from a separate channel than main (intros, presentation videos) at conferences.
mzdonuth
Post by mzdonuth »
Please Resolume Team,.. respond this topic.
add individual audio outputs for each layer .This feature is critical for audiovisual performers, allowing us to:
Use External Effects: Send a single layer (e.g., a synth) to an external processor like a synthesizer or effects pedal, while other layers remain clean.
Professional Live Mixing: Give a FOH sound engineer separate audio channels (drums, bass, etc.) for a proper live mix on the main PA system.
Simplify Workflows: Eliminate the need to run a separate DAW (like Ableton Live) simultaneously, which is CPU-intensive and complicates setups.
Adding this feature would make areana / Avenue a true all-in-one audiovisual performance tool and would significantly improve our workflow.
mzdonuth
Key Feature Request: Per-Layer Audio Outputs in Resolume Avenue
Post by mzdonuth »
To the Resolume Team,
Please add individual audio outputs for each layer in Resolume Arean/Avenue. This feature is critical for audiovisual performers, allowing us to:
Adding this feature would make Avenue a true all-in-one audiovisual performance tool and would significantly improve our workflow.
