Audio playback problem
Re: Audio playback problem
Are you seeing this issue? viewtopic.php?f=12&t=20831
VJ_Autopilot
Post by VJ_Autopilot »
Dont know. On my machine the audio glitch happens without column switching.
But difficult to reproduce. Happens from time to time. Once an hour or so.
Sounds like the same issue, if the clips are looping.
VJ_Autopilot
Clips are not looping. They are quite long. 2-4 minutes.
crayfishuk
Post by crayfishuk »
This is exactly what we are seeing too - Resolume 7, latest 7.13.2
During performance of the show, we have up to 8 layers (7xvideo+audio, 1xPNG) at any one time. Layers are set to ignore column triggers, videos are DXV3+alpha+audio (48kHz).
PC: Media is on NVME M.2, CPU Ryzen 5 @ 3.8GHz, 32GB RAM, Windows 10 fully updated
Audio is Dante @ 48kHz using ASIO driver
We have about 120 columns, most of which are firing a new video (a character speaking) while the other layers (other characters) continue to run. We are three nights into the run, and have had up to about 10 misfires. Tonight was only 4... Each time it misfires the audio is absent for the first second or so, but the video runs fine and then the audio comes in.
There doesn't seem to be any consistency to it. I can run the show without issues, and fails to go wrong, as it happens and vanishes within a second, I can't see anything useful happening.
Cues are fired via OSC using Zoltan's Controller for Resolume, so I don't know if Resolume lags during the issue...
Looked to download 6 instead - but it seems our licence is only valid for 7, and I no longer have access to the old v6 licence that was a previous colleagues.
If the project was built in R7 - is it possible to back-version and load it in R6, assuming I can get it activated somehow??? Next performance is on Monday, and we run all next week....
Thanks in advance...
-Craig
Should be fixed in the next release.
