VJcontroller
What protocol should VJcontroller talk to Resolume?
Poll ended at Thu Sep 01, 2022 04:06
MIDI
1
25%
OSC
2
50%
DMX over ArtNet
0
No votes
Webserver commands
0
No votes
Some of above
1
25%
All of above
0
No votes
Something different
0
No votes
Total votes: 4
jim
Re: VJcontroller
Post by jim »
Hey, sorry for update.
First test unit arrived. What it is is an amalgamation of a couple of different knock off brand control desks. Which I'm using as my testing base. I'm also mounting a mac mini m1 logic board from a trashed one I got on ebay.
Final device will be a usb-c connection, at what ever the lowest level possible with enough bandwidth, for compatibility. It's serial signals and a single 1080p video signal for the screen. I think usb3.0 or 3.1 should be fine, so still easy to run down the line in a thunderbolt 4 Hirarchy.
I am using most likely ALPs Alpine faders, same as DJMs, and Mx gaming key frame, for easy of customisation and repair. I've been more frequent updates on instagram.
jim
Re: VJcontroller
Post by jim »
Here is a chat with my electrical engineering guru Joffy , about micro-controller selection.
On I think I'm pretty set in using ARM architecture now.
The one thing I want to look at now is seeing if I can use SRT or another IPvideo format to take video source from the host computer to run the screen of the controller.
I don't want to use NDI because I don't want to be beholden to NewTek. I also don't want to use up a video output from the host machine that they might need for VJing, especially if they are using a mac.
Also, I am not reading or looking at any replies on this forum at the moment, because dont want to deal with my ego, whether positive or negative, getting in my way. But once this bout of engineering is finished I will catch up.
jim
Re: VJcontroller
Post by jim »
The BlueNRG-LP features a 64 MHz, 32-bit ARM® Cortex®-M0+ core, 256 KB programmable Flash, 64 KB SRAM, MPU, and an extensive peripheral set (6x PWM, 2x I²C, 2x SPI/I2S, SPI, USART, UART, PDM, 12-bit ADC SAR). It is compliant with the Bluetooth® LE specification, supporting master, slave, and simultaneous master-and-slave roles, data length extension, 2 Mbps, long range and extended advertising and scanning features.
So I have a couple of different STM32 chips on order to test, but I am also going to look at some other ST chips like this low power Bluetooth 5.2 chip.
