Link audio FFT to timeline
Tschoepler
Re: Link audio FFT to timeline
Post by Tschoepler »
:lol: nice one!
meiuqer
Post by meiuqer »
Dont know why, but it's not working with me.
Do you have the set up something before using the effect?
VJair
Post by VJair »
turn on osc in avenues preferences.
meiuqer
Post by meiuqer »
yeah thats what i did, still not working, should i check the 'bundles' box also?
and what about the port? it's on 7000.
meiuqer
Post by meiuqer »
My 'step 1' parameter is doing his job, instantly jumping when a kickdrum hits, but my timeline stays the same.
layer1/clip1/video/position/values
this is what i used as OSC Command
/layer1/clip1/video/position/values
The first slash is important too.
meiuqer
Post by meiuqer »
don't wanna be a pain in the butt but it still isnt working :)
do i have to change anything at the Clip Properties? Or somewhere else?
I enabled OSC at the Preferences.
Is there a clip 1 in layer 1, and is it playing?
meiuqer
Post by meiuqer »
Yep, I really cant see what I'm doing wrong
clip properties.jpg (35.84 KiB) Viewed 13789 times
clip effect.jpg (53.25 KiB) Viewed 13789 times
VJair
Post by VJair »
if you unassign ir osc, does the clip play or does it stay paused?
