Yes it is....
But what for???
What do U need???
Step Sequencer for Resolume Avenue and Arena 6 - Max patch
Re: Step Sequencer for Resolume Avenue - Max patch
To use with monome and ms pinky!
hi
i dont get it working.
maybe because of the host adress ?
my computer receives the ip adress automatically from the router. what to do.
and do i have to buy max ?
thanks ben
thanks ben
- Tschoepler
no you dont have to buy MAX. MAX Runtime can be downloaded at cycling74.com for free. It's like with FlashPlayer and Flash.DAS BEN wrote:hi
thanks ben
As long as both apps (MAX and Avenue) run on the same system keep the ip 127.0.0.1 That's like telling the application: "hey we don't send data outside to the router/internet/ethernet/or what not, but we send it to another app (Avenue in this case) on the same computer.
Hi!
I'm using step sequence, but the video starts very quickly. is there a way to start a video, and make it last for its entire length, when he finished another? I can not find any command that allows me to do
- Tschoepler
the purpose of a step sequencer is a different one. anyway, it is possible. but you would have to parse the length of the clips to the sequencer. and that means writing a new patch. I don't have the time for this but if you find a max-coder he could use my xml-parser from the compEditor patch.
Still using this sequencer???
Cause I made a lot of modification on it....
including a bpm time switcher....
A midi recording sequence....
and midi routing....
interested??? let me know....
Yes, of course,zuvassin wrote:Still using this sequencer???
Salut Les normands.... Bon et bien, je regardais votre demande...
donc voila la nouvelle version que j'utilise en soirée...
Le bpm time switcher est encore au stade Alpha.... cest une demande d'un pote Vj....
Perso j voyais vos installs sur le myspace... Chapeau les projets....
ON est presque voisins.... ( Maine et loire) donc si vous souhaitez un coup de main....
Cordialement
Delavaud Emeric
Aka Zuv (Zuvassin)
Cordialement
Delavaud Emeric
Aka Zuv (Zuvassin)
- Attachments
- Zuv Sequencer.zip
- (81.47 KiB) Downloaded 1486 times
Super !
je m'en vais essayer cela de suite
Merci et à bientot voisin
