You got it dude, what are you waiting for?- set the composition to 2400x600 or 1920x480 the better it goes;
- set output to display 2;
- adjust layers´ sizes and positions to virtually match 'screens' positions. TH2go will do the rest, spliting the images (layes´positions) to the correct output (display device).
multi screen Avenue setup
Re: multi screen Avenue setup
Yes, but now I realize I have a new issue:
I found a solution but I lost all possible control over matching projected images.
In a 1600x600 composition, for instance, using two projectors with 800x600 res and some 1600x600 full clips in a single layer, all matching becomes physical. I mean.. projectors must be placed precisely and there will be no control to help macthing edges/seam. Course I can help myself and use Avenue effects to control and position 800x600 layers, with a better matching result. But triggering two 800x600 clips at once and still be capable of mixing and adding effects simultaneously is a crazy idea.
Am I missing anything else again?
tks
Paulo
tks
Paulo
I normally prefer using a second graphics card than using the TH2Go, This allows positioning each screen separately in the advanced output window.
Tim
Tim
